+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 5
    Points: 1,738, Level: 9
    Achievements:
    7 years registered
    Join Date
    Jan 2012
    Posts
    94
    Points
    1,738
    Level
    9
    AT89s51 programmer and DB25
    Click image for larger version.
    Hiiii ....
    Can any one tell me the circuit attached below will run...??? Or something has to change..
    Actually I have 5(five) AT89S51 IC's and they are wasting without Programmer ..
    I read all the Posts and reply's on to making AT89S51 & AT89C51 programmer but there is no efficient technique for programmer...and I waste so much...
    So please help me to make perfect Programmer ...thanku ...!!!
    •   AltAdvertisement
  2. #2
    Advanced Member level 5
    Points: 33,525, Level: 44
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    tpetar's Avatar
    Join Date
    Sep 2010
    Pancevo-Belgrade, Serbia
    Posts
    6,427
    Points
    33,525
    Level
    44
    Re: AT89s51 programmer and DB25
    Simplest 25-pin LPT 89S51/52 programmer :
Name:	Asim's ISP loader.GIF
    From USB port you can take 5V.
    Tested and working like charm.
    •   AltAdvertisement
  3. #3
    Member level 5
    Achievements:
    7 years registered
    Join Date
    Jan 2012
    Posts
    94
    Points
    1,738
    Level
    9
    Thank you very much... sir
    there one problem ..I have ISP programmer which I use NXP P89v51RD2BN MCu IC , I programmed this IC 40 to 50 times and it is working but now it is not working properly when Flash magic show Reset the device in ISP mode and I hold the reset button then it is not reset at all...I mean what is the problem..can U tell me please...Im confused
