i have to simulate my project in proteus...it is about voice recording using mmc card...but in proteus have to face some problem with mmc...i think it can't read...can anyone help me???
i am using hi tech c...i don't know how to read mmc card...i tried to make .mmc image by winhex...but couldn't..i had made blank.mmc txt file...but i think it is not working...actually this is my 1st work with mmc..i have very little idea about it
as i said the access of memory card with pic 16f877a is difficult (RAM limitation). you need 512 b minimum for block write read and all those sort of stuffs. So, what you should do is , go with 16fXX and using a 256 b buffer, try to access the card or use 18fxx series uCs (having more than 1kb RAM).
Please i would like to ask, if i could view the text file i place in my mmc from my compuer i.e as if the mmc is actually in my laptops physical card slot while proteus simulation is going on.
