+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 4
    Points: 565, Level: 5
    Robin Khosla's Avatar
    Join Date
    Aug 2012
    Posts
    76
    Points
    565
    Level
    Blog Entries
    Requirements for image processing on FPGA
    I am working on a project in which i want to read images from a camera and compare it with images stores in external device such a pen drive.and then display the matched image on crt.....
    Is this possible ...
    If yes then what are the requirements for this project??
    E.g.
    Is xilinx virtex6 good enough to do this work and does it have a usb port??
    Which camera shall i use??
    •   AltAdvertisment
  2. #2
    Advanced Member level 5
    Points: 36,316, Level: 46
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,638
    Points
    36,316
    Level
    46
    Re: Image processing on fpga
    1. Yes it is possible.
    2. Requirements will be to read an image from external device and compare it to the image off the camera.
    3. Yes. It can have any interface you want so long as you write or connect in the controller for such a device. FPGAs do not have "ports", just a load of general purpose IO. You can connect whatever interface you like (ethernet, USB, RS232 etc). But you have to either write the controller for it, or get someone else to do it for you. A USB controller is very complex and you will have to pay someone (probably a few thousand dollars) to get the IP.
    4. Whatever camera you want.
    1 members found this post helpful.
    •   AltAdvertisment
  3. #3
    Member level 4
    Join Date
    Aug 2012
    Posts
    76
    Points
    565
    Level
    Blog Entries
    problem solved
    camera can be any
    FPGA can be any probably greater series than spartan-3, however i have not tested on spartan-3, but tested on virtex-5
    the thing is that an external ram is required to store the large amount of video data to do some image process of it.
    however spartan-3 supports only 3-bit i.e. 8 colours so better option is to go with high end FPGA's
    •   AltAdvertisment
  4. #4
    Newbie level 3
    Points: 19, Level: 1
    Join Date
    Sep 2013
    Posts
    Points
    19
    Level
    Re: Requirements for image processing on FPGA
    can you send me code for this
  5. #5
    Member level 4
    Join Date
    Aug 2012
    Posts
    76
    Points
    565
    Level
    Blog Entries
    you can get the reference code from digilent website
