lhlbluesky
Banned
I have two questions here.
in on-chip OSC circuit, R (internal resistor for reference current generation, Iref=Vref/R) and C will all vary with process deviation, and the deviation for R or C can reach +/-30% or larger, so the OSC frequency can change a lot relative to the typical value when process deviation occurs. in order to calibrate the process deviation due to R and C, frequency calibration is always used, such as using programmable current source to charge or discharge the capacitor. now ,i want to know:
1, how to calibrate the process deviation simultaneously caused by R and C? and will the programmable current source be ok? or any other methods should be used? i need your help, some papers or advice will be appreciated.
2, there is a calibration formula used to calibrate the clock frequency when using the chip, that is, we collcet many samples of tested clock frequency (to an excel table), and obtain a formula to get a register value, send this value to the chip to change the programmable charging current, so the frequency can be calibrated to the desired value. now, i want to know, how to get the calibration formula? what is the procedure of getting the formula? pls help me, thanks .
thanks all.
thanks all.
