AMSA84
Advanced Member level 2
- Joined
- Aug 24, 2010
- Messages
- 577
- Helped
- 8
- Reputation
- 16
- Reaction score
- 8
- Trophy points
- 1,298
- Location
- Iberian Peninsula
- Activity points
- 6,178
Hello there guys,
I have a doubt here regarding the interpretation of the maximum rating of ID current.
In the datasheet we can see that the drain current (continuous) @Tc = 25ºC is 22A and @ 100ºC is 15A.
On other hand, there is IDM current, that is the Drain current (pulsed), which can go up to 88A.
My question is, imagining that we are designing a BUCK converter, for example, we have to look to the IDM current or the ID current, for example @ 25ºC?
There is a note which says that the "Pulse width limited by SOA". This means that the current will be function of the width of the pulse? Supposing that I want 20A, @ 100KHz, the 100KHz operating frequency must have a maximum width of 100us?
I have another question, regarding the Ciss capacitance. The graphic that the datasheet presents is only @ 1MHz. Supposing that we will operate the converter at 100KHz how do we know the Ciss capacitance at that frequency? Or the Ciss @ 1 MHz is the worst case, then we can compute, for example, losses with the Ciss value @ 1MHz which will be the worst case?
Best regards.
Best regards.
