Help with verilog testbench for cic filter.
H.Hachem
Junior Member level 3
Hey everyone,
I wrote a code for a cic filter using Verilog HDL. However, I do not know if my problem lies in the testbench I have written or in Multisim. I would appreciate it if someone could tell me if something is wrong in the following short test bench.
module test;
reg clk;
wire [7:0] x,y;
assign x=8'b 00000001;
wb_hp_f (.clk(clk),.x_in(x),.y_out(y));
initial begin
clk=1'b0;
end
always
#1 clk=~clk;
endmodule
I simply want to start by testing the response to a series of ones. The code I used is the one in 'digital signal processing with FPGA' with minor modifications.
Thanks in advance
what is the problem right now? can you post the output or the error message?
No error. its just everything is at constant 0 in Multisim and never changes!
remove
and put
x = 8'b00000001;
inside initial block
and keep on changing it like
this
initial
begin
x = 8'b00000001;
#2;
x = 8'b00000010;
#2;
x = 8'b00000011;
#2;
x = 8'b00000100;
end
and let us know the result
remove
and put
x = 8'b00000001;
this
initial
begin
x = 8'b00000001;
#2;
x = 8'b00000010;
#2;
x = 8'b00000011;
#2;
x = 8'b00000100;
end
declare 'x' as reg type and not as wire as it is an input to your testbench.
Thanks for the replies. I managed to get it to work. It was a Modelsim problem, it was detecting my code as VHDL. Anyway, I'm facing another problem now. After running the test, the simulation does not get past i0 . Here is my code:
module cicdecim64 (x_in,y_out,clk);
input					clk;
input 	[7:0]		x_in;
output 	[7:0]		y_out;
parameter hold=0, sample=1;
reg					state; 	//sample or hold states
reg		[5:0]		count;	//count till 63 starting from 0
reg		[7:0]		x;			//input
wire		[23:0]	sx;		//sign extended input
reg		[23:0] 	i0;		//Integrator output section 0
reg 		[18:0]	i1;		//output section 1 under the consideration of Haugenauer's pruning
reg 		[13:0]	i2;
reg 		[11:0] 	i2d1, c1, c0; // Integrator+COMB 0
reg		[10:0] 	c1d1, c2;
reg 		[9:0] 	c2d1, c3;
always @(negedge clk)
begin : FSM  					// finite state machine
case (state)
hold : begin
if (count<63) 					// setting states for downsampling
state <= hold;
else
state <=sample;
end
default :
state <= hold;
endcase
end
assign sx={{16{x[7]}},x_in};
// Integrator
always @(posedge clk)
begin: I
x  <= x_in;
i0 <= i0+sx;
i1 <= i1+i0[23:7];
i2 <= i2+i1[18:5];
case (state) 					//downsample
sample : begin
c0 <= i2[13:1];
count <= 0;						//reset counter once a sample has been fetched
end
default :
count <= count+1;
endcase
end
// COMB
begin: COMB
i2d1 <= c0;
c1   <= c0-i2d1;
c1d1 <= c1[11:1];
c2   <= c1[11:1]-c1d1;
c2d1 <= c2[10:1];
c3   <= c2[10:1]-c2d1;
end
assign y_out=c3[9:2];
endmodule
Modelsim shows only clk , x_in , state, count, sx but everything else is constant red line. I guess the problem lies in ' i0 <= i0+sx ', since i0 is not predefined before this statement, modelsim is unable to calculate it. I tried predefining i0 but to no avail. Any ideas?
Thanks in advance.
Hi you havenot intialised any values using reset including your state. Try to change the logic of your coding
Could you give me an example? I took the code from a book and modified the downsampling rate to suit my project
The Verilog standard specifies
The initialization value for reg, time, and integer data types shall be the unknown value, x.
If you don't implement an explicite reset signal, you have to supply initial values to make the simulation work.
Yes, that makes sense. I tried inserting the following after the declaration of ports and wires:
always @(posedge reset)
begin
i0<=24'd0;
i1<=19'd0;
i2<=14'd0;
end
while setting reset to jump from 0 to 1 at the beginning of the simulation. However, the compiler returns the following error:
Error (10028): Can't resolve multiple constant drivers for net "i0[23]" at wb_hp_f.v(45)
I used
initial begin
i0<=24'd0;
i1<=19'd0;
i2<=14'd0;
end
instead and got the code to compile. However, the problem with the simulation persists. Once a posedge clock is reached, we're back to the same point as before. :/
The reset action must be placed in the same always block driving the respective registers to avoid a multiple drivers error.
The initial block should generally work, but may be you have other signals that are undefined during the first clock edge. You can find out by thoroughly looking at the simulations results. It's just an everydays HDL simulation problem, a practioneer will solve in on the way without much thinking.
I'm still struggling to get it to work. I only get the 1st output sample because of the initial values. However once the first positive clock edge occurs, the state of i0 changes to x and with it everything else. I tried changing the clock frequency but that did not help.
This is the case at least for x. Why don't you trace the values of all involved variables in your simulation. That's waht simulation tools are made for.
OK let's see here is my code now:
// cic decimation filter : R=64, M=1, N=3
module cicdecim64 (x_in,y_out,clk,reset);
input					clk,reset;
input 	[7:0]		x_in;
output 	[7:0]		y_out;
reg 		[13:0]	i2;
reg 		[9:0] 	c2d1, c3;
case (state)
hold : begin
state <= hold;
else
state <=sample;
end
default:
state <= hold;
endcase
end
// Integrator
always @(posedge clk)begin
if(reset) begin
i0 <= 24'd0;
i1 <= 19'd0;
i2 <= 14'd0;
x  <= 8'd0;
end
else
x  <= x_in;
i0 <= i0+sx;
i1 <= i1+i0[23:7];
i2 <= i2+i1[18:5];
sample : begin
c0 <= i2[13:1];
end
default :
count <= count+1;
endcase
end
// COMB
begin: COMB
i2d1 <= c0;
c1   <= c0-i2d1;
c1d1 <= c1[11:1];
c2d1 <= c2[10:1];
end
endmodule
Test bench:
`timescale 1ns/1ps
module test;
reg				clk,reset;
reg	[7:0] 	x;
wire 	[7:0]		y;
cicdecim64 cic (x,y,clk,reset);
initial begin
x <=8'd1;
clk<=1'b0;
reset <= 1'b0;
#4 reset=~reset;
#5 reset=~reset;
end
always
#4 clk=~clk;
endmodule
Simulation :
As you can see reset is only resetting x and ignoring the others.
Earlier, I tried to follow your suggestion. Everything before i0 (including x and sx) was defined all the time. This means the problem lies in i0 <= i0+sx;
You have to care, that the reset is applied to all register signals at the same time. That's apparently not the case in your testbench.
If you use a synchronous reset, the reset signal must not be applied exactly at the clock edge, this causes a race condition.
hello,
I have the same problem, I am new to DSP and verilog.
I am an analog designer and I need CIC filter for sigma delta ADC,
can u help me with the test bench code , I used Meyer code for DUT with some modifications
