1 Wire to RS232 Serial Interface
technofreaks
Bangalore
1 Wire to Serial Interface Circuit using max3232E IC, This interface can daisy chain 1Wire device such as 18S20
Supply Voltage 5VDC, (schematic / ready PCB is available )
What MAX3232? 1-Wire dont need MAX232 or MAX3232.
RS232 Active 1-Wire Adapter 9-pin 9097U
RS232 Passive 1-Wire Adapter 9-pin 9097E
USB 1-Wire Adapter 2490
Yes it can be done with out MAX3232, its a Level converter, instead you can use transistor / doide
2490 is USB version, I have made circuit for USB also.
technically speaking it's not one wire am I correct in saying you still have to connect the GND as well, if so this is 2 wires
it reguires return path which is GND , Two wire communication (SPI) will have 3 wires so on..
A funy circuit.How about the cost?If cost up is more than one wire cost,it may be without valuable.
oh,it's so expensive.For RMB,it needs about 74
