N
nks7
what is reverse active bias
how to minimize it for any logic circuit
Refers to the operation of the a bipolar transistor. In normal operation, which is foward active, the emitter-base junction is foward biased and the collector-base junction is reversed biased. Therefore, reverse active bias is when the emitter-base junction is reversed biased and the collector-base junction is foward biased. The result is your BJT is acting as an up-mode transistor, which is when electron flow from the collector to the emitter region. People designing I2L logic gates used npn transistor operating in the reverse active mode.what is reverse active bias
Don't hook up the transistor backwards. Just remember that for npn devices, the emitter should be at a lower potential vs. the collector (but the opposite applies for vertical pnp devices).how to minimize it for any logic circuit
