+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 3
    Points: 336, Level: 3
    Join Date
    Dec 2011
    Posts
    Points
    336
    Level
    TFT LCD powered by arduino
    I am wanting to design a simple unit that controls relays to active a 12v motor(pump). I want to be able to display the volume of the tank on an LCD, preferably TFT so I don't have to add additional buttons. The volume will be calculated from time which the pump is on. I would like to use a 4.3" LCD and does not need to be multicolor. Does anyone have any suggestions where to start?
    •   AltAdvertisement
  2. #2
    Super Moderator
    Points: 8,492, Level: 22
    Join Date
    Jun 2009
    Japan
    Posts
    1,065
    Points
    8,492
    Level
    22
    Re: TFT LCD powered by arduino
    Hello!
    Does it mean you want to use a touch-panel LCD? Or does it mean that you will
    set a kind of contextual menu bar explaining for each situation:
    Situation Si
    Button 1 = Action Si1
    Button 2 = Action Si2
    i being a number from 1 (first context) to N (last context).
    Some thoughts:
    - You don't need color TFT, but you will probably not find any monochrome TFT. In fact, monochrome TFT
    do exist for high end applications (digital radiography), not for Arduino-like student projects.
    - If you use Arduino, you will likely need a TFT with integrated controller. But I doubt you will find that kind
    of product as large as 4.3 inch.
    By the way, if anybody knows a 4.3 inch TFT (or larger) with integrated controller, please provide a link. Thanks.
    Dora.
    •   AltAdvertisement
  3. #3
    Newbie level 3
    Join Date
    Dec 2011
    Posts
    Points
    336
    Level
    I found this TFT module online.
    http://imall.iteadstudio.com/display/tft-lcm/im120419007.html
    It says that it can be interfaced with a arduino mega. It might be a bit slow but I won't be using an extensive amount of graphics. What are your thoughts?
    •   AltAdvertisement
  4. #4
    Super Moderator
    Join Date
    Jun 2009
    Japan
    Posts
    1,065
    Points
    8,492
    Level
    22
    Hello!
    I have looked at the link you provide. Yes, apparently you can use any kind of MCU.
    As for the speed, it can be quite fast if you refresh only the part you need to.
    1 2-byte word will be 1 pixel, so for example painting the background with a uniform
    color would be fast.
    Example: clock = 20 MHz. 1 loop = 10 clocks. Painting 480 x 272 pixels will take
    about 7 ms. (this supposes that the data bus is 16-bit wide). These figures may vary
    depending on the processor, clock frequency, how much time for a loop, etc...
    Dora.
