Results 1 to 8 of 8
    Advanced Member level 3
    Points: 3,812, Level: 14
    Jun 2011
    839
    3,812
    14
    Altium 10: Erros when using it mainly in library.
    I have been trying to lay out a small PCB in Altium but i am getting huge numbers of errors.
    I put four different components into the library.......then put these on schematic, then transferred to pcb no problem.....but then as i added more compnents i am getting huge numbers of errors...as follows...
    The most common error i get is a little dialog box popping up headed "Information"....it just says "please wait a moment", and a green scroll bar rolls forward several times underneath it.
    The other errors are here....each one separated by dashed lines...
    Catastrophic failure
    Access violation at address 00000000. Read of address 00000000
    Dxp
    Access violation at address OD5C6F34 in module @IntegratedLibrary.DLL’. Read of address E1E8000C.
    Error
    Information
    Integer overflow at 6F16E009. Exception occurred in SaveObject.
    does anyone know why i am getting these errors?
    At first it was fine, but then they all just started.
    Full Member level 5
    Points: 3,114, Level: 13
    loosemoose's Avatar
    Dec 2008
    Vancouver, BC
    319
    3,114
    13
    Re: Altium 10: Erros when using it mainly in library.
    maybe the file got corrupted?
    Advanced Member level 2
    Points: 5,509, Level: 17
    Dec 2006
    India
    512
    5,509
    17
    Try re-installing your software.
    or as loosemoose said that file might be corrupted so try opening some other file if the problems still occur tha re-install you software or contact support centre.
    You can also check if your file is corrupted or not by opening it in some other system.
    Jun 2011
    839
    3,812
    14
    Thanks, i have tried starting again in a new project but the fault is still there......so i think i will try an d re-install software as you say.....but is it likely to have been corrupted.
    I did a schematic using symbols but no footprints attached to them and it was fine......its all happened since i started doing footprints.
    I am just wondering if the library i created has to be an "integrated library" for it to work properly?
    Dec 2006
    India
    512
    5,509
    17
    Check the Footprint Library path assigned there could be a error in that also. Check for special characters(@#% etc.) sometimes this could cause an error.
    Also did you tried to open you file in some other system?
    Jun 2011
    839
    3,812
    14
    well today i updated via the web and the problems have virtually gone.....so far.
    I am wondering if this is Altium putting bugs in the software so that if you dont update regular then it crashes on you...this would be a good way for them to catch software copiers?
  7. #7
    Newbie level 1
    Points: 13, Level: 1
    Jun 2015
    13
    Erased all Altium Windows registry using regedit.exe and everything works fine. I guess Altium for some reason save those address in the windows registry.
  8. #8
    Advanced Member level 1
    Points: 3,036, Level: 12
    May 2013
    417
    3,036
    12
    Quote Originally Posted by grizedale View Post
    I don't think they're putting in these errors intentionally, I have a legitimate copy of Altium Designer (university sponsored), I'm using the latest version and I also regularly get these nonsense errors thrown into my face.
