omkar.991
Newbie level 2
Hello Friends,
I am trying to design a moving average filter in FPGA. Using Xilinx Spartan 3A DSP XC3SD1800A.
I am getting XST 646 error. I am unable to locate the root of the problem.
I have tried to create an array of 12 bit word of length 2 to begin with. I am adding the 12 bit word and dividing by 2. But the RTL schematic is not showing a FIFO stack getting synthesized. It shows the error XST 646 avgA(0) not used or assigned. I have gone through the code again and again but failed to find the fault. I am posting the relevant portion of the code. Please help me.
Note:- signal count2 is a counter to execute the operations after a predefined clock cycles. signal "start" is used to fill the stack upto the desired length with fresh data(here length=2). After it is completely filled, FIFO action should continue.
entity Position_Estimator is
port( clk : in std_logic;
curr : in std_logic;
start_conv : in std_logic;
output : out std_logic_vector(11 downto 0);
A2 : out std_logic;
A1 : out std_logic;
A0 : out std_logic;
sclk : out std_logic;
sgl : out std_logic;
range1 : out std_logic;
cs : out std_logic);
end Position_Estimator;
architecture Position_Estimator of Position_Estimator is
signal xoutA:unsigned (11 downto 0):="000000000000";--
signal favg_A:integer range 0 to 4095:=0;
signal xcs,xsclk:std_logic;
signal count2:integer range 0 to 34:=0;
signal start : integer range 1 to 3:=1;
signal sumA: unsigned(12 downto 0):="0000000000000";
type FIFO is array (0 to 1) of unsigned(11 downto 0);
signal avgA:FIFO:=(others => (others=>'0'));
begin
range1<='0';
sgl<='1';
A2<='0';
cs<=xcs;
A1<='0';
A0<='0';
sclk<=xsclk;
process(clk)
begin
if rising_edge(clk) then
if count2=30 then
if start=1 then
avgA(0)<=xoutA;
elsif start=2 then
avgA(1)<=xoutA;
else
avgA(0)<=avgA(1);
end if;
elsif count2=31 then
avgA(1)<=xoutA;
end if;
end if;
end process;
process(clk)
begin
if count2=34 then
sumA<="0000000000000";
elsif count2=32 then
for i in 0 to 1 loop
sumA<= sumA + avgA(i);
end loop;
end if;
end if;
end process;
process(clk)
begin
if count2=33 then
favg_A<=conv_integer(sumA)/2;
end if;
end if;
end process;
process(clk)--
begin--
if rising_edge(clk) then--
if count2=34 then
if start<3 then
output<=conv_std_logic_vector(xoutA,12);
else
output<=conv_std_logic_vector(favg_A,12);
end if;--
end if;
end if;
end process;--
A2 : out std_logic;
A1 : out std_logic;
A0 : out std_logic;
begin
range1<='0';
sgl<='1';
A2<='0';
cs<=xcs;
A1<='0';
A0<='0';
sclk<=xsclk;
process(clk)
begin
if count2=30 then
if start=1 then
avgA(0)<=xoutA;
elsif start=2 then
avgA(1)<=xoutA;
else
avgA(0)<=avgA(1);
end if;
avgA(1)<=xoutA;
end if;
end if;
end process;
process(clk)
begin
if count2=34 then
end loop;
end if;
end if;
end process;
process(clk)
begin
if count2=33 then
end if;
end if;
end process;
process(clk)--
begin--
if count2=34 then
if start<3 then
else
end if;--
end if;
end if;
end process;--
