advantages of audio ic 810 over 820
rajaram04
Advanced Member level 3
earth
Hello sir,
I want to know about the advantages of audio ic 810 over 820 , which is best or say which one has the limit to drive a particular speaker & something like that i want to know !
Both are pretty old devices, and both are obsolete. TBA820 is (was) very popular, and easier to use because
it is supplied in a normal package. Go with that unless you really need loads of power.
If you are looking for other simple audio amp ICs for low power, then TDA7052B is a reasonable choice too, it is
not obsolete, and needs slightly less external components compared to TBA820.
If you want slightly higher power and stereo, then consider TDA1517.
okkk sir thanks a lot for the info :)
