how to make connections for 1838 ir phototransistor
rajaram04
Advanced Member level 3
earth
Hello sir
Im using a 1838 IR photo transistor but its not working with simple circuit configuration as i did in tsop series.Now i ve this type of ir phototransistors available only.So please tell me about the simple circuit diagram of the 1838 so as to get proper output when exposed to ir rays.
thanks
Can you provide a link to the datasheet?
I cannot find any photo transistor with 1838 in the part number, only more receiver modules like TSOP1838
Reactions: asking
    asking
yes thats it sir its of TSOP series alose but this one is not working like previous ones of big size dimensions & that sensors are not available now in market.i ve today only these sensors with a metal cover on it n very small size , usually im using it in usb players but wen using it in common experiments it was a big failure & no simple circuits as i did in previous are applicable here , im sending the link here please visit sir
https://www.digchip.com/datasheets/parts/datasheet/000/TSOP1838-pdf.php
There is an application circuit in the datasheet. If it is for a hobby circuit, you might omit the 4.7uF capacitor and replace the 330 Ohm resistor with a wire link.
Reactions: asking
    asking
hmm,sir did everythying including what u told but still not getting result , first time i get so much frustrated to do so cause it was so easy some years back with sensors im showing here & not available now please see below
https://www.lirc.org/ir-audio.html
i used this one as per the circuit digram n was qt simple,but now the available one is harassing me sir , please help & get me the proper biasings for 1838 :(
All TSOP-like IR remote control receivers are opreating similarly, they differ however in carrier frequency. Most RC commanders are using 38 kHz, 40 or 36 kHz should be still received with an TSOPxx38 receiver with reduced sensitivity.
All these receivers can be expected to output a pulse sequence when receiving a RC commander signal.
ok sir so can you provide a commonly used circuit digram related to a ir sensor or photo transistor please ? i will follow your new configurizwd circuit sir
If you are using a microprocessor to receive domestic TV IR signals then the attached JPG file will work. Hardware is simple, all the work is done in software.
If you are using discreet components I cannot help you. I have only ever used a microprocessor to decode TV remote signals
https://obrazki.elektroda.pl/2536185100_1379342258.jpg
You must put a 0.1uF decoupling capacitor across the supply wires of every logic IC in your circuit (including TSOP1838) as close as possible to the IC supply pins.
EDIT: oops... just spotted that this thread is very old :(
thats okk sir thanks a lot , old is gold & a new small information for an unknown is always as new as it was previous :p
thanks once again
