Problem with port defined as inout in a module (Verilog)
lokeyh
Question on Verilog
Hi all,
I am new to verilog. I have a problem.
I have a port on a module that is defined as inout. Sometimes, I need to drive it with a signal and sometimes, the port need to drive a signal. VCS gives errors when I drive the port with register. What should I write in the testbench to avoid that error.
Thanks.
Re: Question on Verilog
assign ur register to a wire and connect this port to a wire ... but make sure u r driving Z when u don't want to drive any value!!!!
Question on Verilog
a module's output must be connected to a wire,iout is also.
Question on Verilog
For inout signal both inside the module as well as during instantiation of that module it should b e connected/driven by a wire.
Question on Verilog
module XXX(
s_inout,
inout s_inout;
wire s_inout;
assign s_inout = s_out_oe?r_inout:z;
Good Luck
you should write your code as follow:
inout bir_signal;
wire oe; // add this control signal
wire signal_input;
reg reg_out;
assign bir_signal = oe? reg_out : 1'b1;
assign signal_input = bir_signal;
one must think about hardware implementation when he(or she) is writing code;
lokeyh said:
Hi all,
Thanks.
