+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 6
    Points: 692, Level: 5
    Join Date
    Jan 2011
    Posts
    12
    Points
    692
    Level
    FPGA Virtex 4-Verilog-Noise amplification
    I have XILINX VIRTEX 4 BOARD. i want to make a project using this board, to Amplify(increase or decrease) the input noise. How can i do this? Need Help? and any help regarding the board anf structure?
    •   AltAdvertisment
  2. #2
    Super Moderator
    Points: 251,591, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    43,812
    Points
    251,591
    Level
    100
    Re: FPGA Virtex 4-Verilog-Noise amplification
    The question is very unclear (with a light smell of confusion). FPGAs are programmable digital logic devices. Which noise signal do you want to process with your FPGA board? Are you talking about digital signal processing? If so, which analog-to-digital conversion capability is provided by your board?
    •   AltAdvertisment
  3. #3
    Newbie level 6
    Join Date
    Jan 2011
    Posts
    12
    Points
    692
    Level
    Quote Originally Posted by FvM View Post
    Thanks FvM for replying. Actually i have to take some audio inside using some FPGA Board whether its SPARTAN 3/3E or Virtex 4(but some one suggested me to use virtex 4 board as this can be easily implemented in this) and then i have to increase or decrease the volume of the sound (Magitude) when taken back at output. (LINE in or microphone for input and Line out or headphone of virtex 4 board for output). i came to know that ML403 virtex 4 uses LM4550 Semiconductor and AV97 codec. if i can get some help in verilog coding to take some audio in the FPGA board and then change magnitude and get output.
    http://www.coe.montana.edu/ee/rosss/...Processing.pdf
    •   AltAdvertisment
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    43,812
    Points
    251,591
    Level
    100
    Much clearer now. Unfortunately I don't use Xilinx and can't help with the programming details. I guess that demonstration program for the Evaluation Board rae vailable, including codec programming.
  5. #5
    Newbie level 5
    Points: 172, Level: 2
    Join Date
    Sep 2012
    Posts
    8
    Points
    172
    Level
    hi, i am also using a vertix 4 board, and don't know much about its coding. can any one please help me in this problem. i'll will be glad if u do.
