uoficowboy
Full Member level 3
- Joined
- Apr 4, 2009
- Messages
- 169
- Helped
- 6
- Reputation
- 12
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- Seattle, Wa, USA
- Activity points
- 2,964
Hi - I'm interested in a circuit that can either multiply one voltage by another (ie V1 * V2 = V3) or one that can divide one voltage by another (V1 / V2 = V3).
In the multiplication case, V1 and V2 are measured voltages in the circuit. In the division case, V1 is a measured voltage while V2 is a generated voltage (generated via a DAC). I could also use a digital pot instead of a DAC, if that would help. I do not expect it to change very often (though it'd be nice to preserve the functionality of changing it often).
I am hoping to achieve very high DC accuracy (hoping to get 12 bits out of the system). The output will be fed back into a control loop - so higher bandwidth is preferred (100KHz+ ideally) (hence why I don't want to do the conversion in a microcontroller). Low cost, ideally.
I can't seem to find anything that can meet these requirements, or that even comes very close to them.
Any suggestions?
Any suggestions?
