addiding white noise to EEG signal
sapanssonar
i want to add white noise to EEG signal plz tell me the solution
well tell us more about your application , what simulation software are you using ? or are you getting output from a true eeg machine ?
i am detecting k-complex using matched filter and DWT. after detecting it, compring their result
1)miss detection v/s noise 2) false alarm v/s noise
so for compring results i want to add noise to EEG signal. i am using matlab 7.9
also tell how to plot comparative graph in matlab?
There are projects that produce white noise, and from more than one type of device.
Some use an NPN with emitter-to-base operated in zener mode, or a zener diode, or a cheap noisy op amp. This method may or may not be available in simulator programs.
There are also commercial chips whose purpose is to generate white noise. An internet search will turn up some. One of these could be among the list of available devices in a simulator.
In matlab we have a AWGN block which can be used for additive white gaussian noise
alright then rock on !!
---------- Post added at 19:32 ---------- Previous post was at 19:31 ----------
and ya keep up the good work
---------- Post added at 19:33 ---------- Previous post was at 19:32 ----------
