SajidAli092
Newbie level 2
Hello Every One.
I need to work on the project. Task is
"Simulate single phase square and quasi square wave inverter with resistive and inductive load. Using the quasi square wave based control design the dead band to eliminate the triplen and fifth order harmonics. Show all the waveforms and analytical analysis and required rating of all the components if output power is 1kW at 220V. Perform the Fourier analysis of type of inverter waveforms. Design an output filter to remove the LOH and prove the effectiveness of filter using waveforms."
Thanks.
Thanks.
