ku637
I ve got a requirement for a PLC module such that the noise should be close to -150dBm/Hz over the frequency range 2-100MHz
checking the EMC test procedures and guide lines .. i feel that upto 30MHz conducted noise is measured & above that radiation noise is problematic
Also all the graphs for conducted noise are showing dBuV Versus Frequecny & for radiated noise it is shown as dBuV/m versus frequency.
1) how can i convert the -150dBm/Hz value to refer in the dBuV versus frequency graph..? simply add 107?
