+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 5
    Points: 368, Level: 4
    Join Date
    Apr 2012
    Chandigarh
    Posts
    9
    Points
    368
    Level
    what is the value of channel length modulation constant in 180nm in mentor?
    How to calculate channel length modulation constant Lambda in ELDO simulator??
    •   AltAdvertisement
  2. #2
    Super Moderator
    Points: 51,877, Level: 55
    Achievements:
    7 years registered
    erikl's Avatar
    Join Date
    Sep 2008
    Germany
    Posts
    8,090
    Points
    51,877
    Level
    55
    Re: what is the value of channel length modulation constant in 180nm in mentor?
    Channel length modulation (CLM) strongly depends on channel length itself, on Vds and on inversion operation mode, hence should be extracted at an appropriate operation point.
    On absence of other conflicting effects which may also affect the gradient of the Id-vs-Vds characteristic (DIBL, hot electron injection), the CLM parameter λ can be calculated as the reciprocal value of the Early Voltage VA (λ = 1/VA) , extracted at the proper operation point from the measured or simulated Id-vs-Vds characteristic, see e.g. Behzad Razavi "Design of Analog CMOS Integrated Circuits" or David M. Binkley "Tradeoffs and Optimization in Analog CMOS Design".
