+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 2
    Points: 3,141, Level: 13
    Join Date
    Mar 2006
    Slovenia
    Posts
    133
    Points
    3,141
    Level
    13
    Monopulse tracking system in HFSS
    Hi all,
    I'm designing a monopulse tracking system. It consist of Rat-race monopulse comparator and a system of 4 dipole antennas. The comparator is working fine, designed in HFSS and measured. Now, the problem is that I want to receive a circular polarized wave. This means that antenna A has to be connected with cable length L, antenna B L + lambda/4, antenna C with L + lambda/2, and antenna D with L + lambda*3/4.
    I do not know if this will work with rat-race comparator, so I designed a HFSS model (see picture).
    The idea is to illuminate antenna with incident field port, and from imag and real part of S parameters at ports Azimuth, Elevation, and Sum calculate the resulting Azimuth, Elevation and Sum.
    My question is: if I place the IncPwave port at the top of the model, will I get the results at the ports on comparator at the bottom of the model. At first glance HFSS does not give me S parameters for IncPwave. I have never used IncPwave and I might be mistaken. What should I do?
    Thank you
    •   AltAdvertisment
  2. #2
    Full Member level 2
    Join Date
    Mar 2006
    Slovenia
    Posts
    133
    Points
    3,141
    Level
    13
    Re: Monopulse tracking system in HFSS
    Let me rephrase my question...
    If I use Incident Wave Port, how can I see what is induced at Wave Port exit?
