ryujinaga
Newbie level 3
hello
i try to read ADC at pin AN0 from a potentiometer and display the digital measurement.the max output voltage of the potentiometer is 5V and to get the digital measurement=vin/5x1023...but then at my lcd show measurement 255 instead 1023. from datasheet, the pic is 10 bit. please explain to me why this happen???
the coding
best regard
the coding
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 #include <16F877A.h> // type of micricontroller #fuses HS,NOWDT,NOLVP,NOPROTECT // high speed oscillator, no watch dog timer #use delay (clock=20M) //20MHz crystal #include <lcd.c> #define LCD_ENABLE_PIN PIN_D0 ////set lcd port #define LCD_RS_PIN PIN_D1 //// #define LCD_RW_PIN PIN_D2 //// #define LCD_DATA4 PIN_D4 //// #define LCD_DATA5 PIN_D5 //// #define LCD_DATA6 PIN_D6 //// #define LCD_DATA7 PIN_D7 float ALL; void main() { set_tris_b(0x00); //set port b as output set_tris_C(0x00); //set port c as output output_b(0x00); //reset port b output_c(0x00); //reset port c setup_adc(ADC_CLOCK_INTERNAL); // set internal clck for ADC setup_adc_ports(ALL_ANALOG); //set s analog input lcd_init(); while (true) { delay_ms(200); set_adc_channel(0); ALL=read_adc(); lcd_gotoxy(1,1); printf(lcd_putc,"\fVDIG=%0.1f",(float)ALL); } }
best regard
