Product Modulator design
sudip_kuet08
Junior Member level 1
Bangladesh
Can anyone please help me to design a product modulator
My signal is S1(t)=sinwct(f=100KHz)
S2(t)=.765(sinwct-135)
I have to multiply this two signal.......................
Thanks
sudip
Any balanced mixer is in principle the "product" modulator, or, a multiplier. The important point is that one of the signals to be multiplied can fully open and close mixer diodes (called a local or pump signal). For diode mixers, the nominal LO level is +7...+13 dBm, or, around 10 mW. The other signal should be lower in magnitude than the first. At mixer output you will get the product of both signals, a DC component corresponding to the LO power, and harmonics of the product. You can separate the unwanted components by filters and by a capacitive output coupling.
Study the mixer basics from a textbook to understand their operation.
can anyone please provide me a circuit diagram.....................???
thanks
sudip
---------- Post added at 14:20 ---------- Previous post was at 14:19 ----------
thanks
sudip
thanks
sudip
thanks
sudip
Please look at "www.minicircuits.com", MIXERS, and Markimicrowave.com, they also have white papers on mixers. Why haven't you even look in a basic electronic textbook?!
you will find some textbook fro your reference.
