+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 2
    Points: 1,955, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jun 2008
    Posts
    43
    Points
    1,955
    Level
    10
    where to check code size in EDK or SDK
    Hi all,
    I am generating an EDK design for microblaze. Because of some project limitations I have only internal BRAM to use as code and data memory. I have made a code which is running fine but now I have to check its size and see how much place I have left with for incresing functionality of my code or edk project.
    please help
    thanks
    •   AltAdvertisment
  2. #2
    Advanced Member level 1
    Points: 4,716, Level: 16
    Achievements:
    7 years registered
    Join Date
    Dec 2007
    Bangalore, India
    Posts
    494
    Points
    4,716
    Level
    16
    Re: where to check code size in EDK or SDK
    Are you using SDK in EDK?
    •   AltAdvertisment
  3. #3
    Member level 2
    Achievements:
    7 years registered
    Join Date
    Jun 2008
    Posts
    43
    Points
    1,955
    Level
    10
    Quote Originally Posted by xtcx View Post
    I am using EDK11.1 in which XPS and SDK can be separately accessed.
    •   AltAdvertisment
  4. #4
    Achievements:
    7 years registered
    Join Date
    Dec 2007
    Bangalore, India
    Posts
    494
    Points
    4,716
    Level
    16
    I'm using 13.1 SDK for all C projects. I remember in EDK, you can see the usage of BRam in the transcript window at the time of running "update bitstream"
    Try seeing the transcript window while running this. You will be able to see the usage....
