alexander123
Newbie level 1
Hey,
I'm working on an adaptive filter, using the CMA algorithm ..
This algorithm need multiple multiplications according to the formula : f(n+1) = f - (e*y*x*µ)
with x = input
y = output
e = error
µ = stepsize
f and f(n+1) = current and next coefficient weight
now the input and output that i'm using is an 8 bit signed signal, the stepsize is a small number (0,001 ex) and the error is equal to e = 1- y^2
i'm having difficulties in how i should implement this equation.
What i'm thinking of now is to do it as followed :
y*x = 16 bits
then multiple this with the stepsize that also is a signed 8 bit signal .( that i use as fixed point 2,6)
so this gives me a 24 bit signal, then scale it down according to the fixed point multiplication.
then i truncate this to an 8 bit signal, and multiply it with the error signal (also a 2,6 fixed point) again perform scaling and truncation.
is this the way it should be done ? i feel there is a better solution .. :s
your comment's are much appreciated.
greetings, alex.
with x = input
y = output
e = error
µ = stepsize
y*x = 16 bits
greetings, alex.
