+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 1
    Points: 150, Level: 1
    Join Date
    Feb 2012
    Posts
    Points
    150
    Level
    [Moved] car audio volume controller system
    I want to build a device that will be connected or embedded to a car audio system in which the volume of the audio system will be controlled by the speed of the car that is , if the car is speeding, the volume will increase and it will decrease as the speed of the car reduces. Please i need useful info on how to go about it. Thanks to u all.
    •   Alt25th February 2012, 22:46
      advertising
  2. #2
    Advanced Member level 5
    Points: 16,136, Level: 30
    Join Date
    May 2010
    Santa Barbara
    Posts
    2,832
    Points
    16,136
    Level
    30
    Re: [Moved] car audio volume controller system
    With old analog radios you might have a chance. There one could control the volume by a voltage-controlled attenuator, like an optoresistor lighted by a tachometer output proportionally.
    Modern radios are computer-controlled, not allowing similar attempts. You will have to design your special audio amplifier to be added before loudspeakers, employing a similar analog control by tachometer output.
    You can also use a wind-driven generator outside of the car to generate the control voltage.
    I do not think it would be a reasonable project. If you want to play, go for it- maybe you could sell your new "speed-driven radio" to dangerous drivers on our roads.
