poojarai
Newbie level 6
Can any one please help me to setup comparator in 16F886.I dont know why code is not working for internal reference.I alway get C1OUTas low. I used A0=negative anaolg ip and A2=internal voltage for comparator1.i think problem is in CR1(CM1CON0) ,when i make it 0 and connect A3= as +ve analog ip ,it works properly .Is there any problem in my code or something else.here is my code.
IC -16F886
Complier version-9.71a
#include "htc.h"
#define _XTAL_FREQ 4000000
__CONFIG(XT & WDTDIS & LVPDIS & DEBUGEN & IESODIS & BORDIS & MCLREN& PWRTDIS &UNPROTECT& LVPDIS & FCMDIS );
volatile unsigned int a=0;
void main(void)
PORTA=0x00; //clear all
ANSEL=0xFF;
TRISA=0b00001111; //set pin0 to pin3 as input
PORTB=0x00; //clear all
ANSELH=0x00;
/*1(VREN)=CVREF circuit powered on
1(VROE)=CVREF voltage level is also output on the RA2/AN2/VREF-/CVREF/C2IN+ pin
0(VRR)= High range
0(VRSS)=Comparator Reference Source =VDD - VSS
0001(VR<3:0>)=CVREF Value Selection 0 ≤ VR<3:0> ≤ 15
When VRR = 1: CVREF = (VR<3:0>/24) * VDD
When VRR = 0: CVREF = VDD/4 + (VR<3:0>/32) * VDD */
VRCON = 0b11100001; // Set voltage reference register
/*1(C1ON)=Comparator C1 is enabled
0(C1OUT)=noninverted out
1(C1OE)=C1OUT is present on the C1OUT pin
0(C1POL)=C1OUT logic is not inverted
0=Unimplemented
1(C1R)=C1VIN+ connects to C1VREF output
00(C1CH<1:0>)=C12IN0- pin of C1 connects to C1VIN- */
CM1CON0 = 0b10100100;
__delay_ms(2); // delay for 2 milliseconds
while(1)
if(C1OUT==1)
a++;
else
a=0;
IC -16F886
#include "htc.h"
void main(void)
ANSEL=0xFF;
ANSELH=0x00;
0(VRR)= High range
0=Unimplemented
while(1)
if(C1OUT==1)
a++;
else
a=0;
