+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 1
    Points: 1,338, Level: 8
    Join Date
    Apr 2011
    Chennai, Tamil Nadu, India
    Posts
    106
    Points
    1,338
    Level
    8
    Spartan 6 FPGA Configuration issue in BPI up mode
    Dear friends
    In my customized board with Spartan 6, FPGA is configured in BPI up mode. In the same bus, a NVSRAM also connected. while loading .mcs file to flash(1Gbit), programming become failed but CFI query, flash erase are succesfully completed.
    I programmed FPGA with .bin file and access the flash from processor.so that I can able to find that some sectors of the flash cannot be written. I was suspecting the Flash memmory and i changed with a 512Mbit flash. Both are spansion s29gl series. But the problem still exists.
    Consistently some sectors showing problem. and i verified the schematics and pcb connections and i cannot find any problem. Also i couldn't find any relation between the problem sectors.
    Plz help ...
    Thanks in advance.....
    •   AltAdvertisement
  2. #2
    Full Member level 2
    Points: 3,118, Level: 13
    Join Date
    May 2006
    Posts
    127
    Points
    3,118
    Level
    13
    Re: Spartan 6 FPGA Configuration issue in BPI up mode
    Looks like configuration mode setting is not proper, please check it.
    •   AltAdvertisement
  3. #3
    Full Member level 1
    Join Date
    Apr 2011
    Posts
    106
    Points
    1,338
    Level
    8
    The issue has been closed. The Reset of flash has been not proper, due to the improper "out of reset" of flash will leads to false memory accessing.
