+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Advanced Member level 2
    Points: 3,889, Level: 14
    iVenky's Avatar
    Join Date
    Jul 2011
    College Station, Texas
    Posts
    584
    Points
    3,889
    Level
    14
    Blog Entries
    10
    Why is the capacitance between gate and drain is almost zero after pinch off?
    Initially we have oxide capacitance between gate and body. But once we have the channel the capacitance gets distributed between source and drain. I just could get this "distribution" thing - Does that mean that there are some static negative charges in source and drain? Also after pinch off there is no capacitance between gate and drain. Why is that so?
    Thanks in advance.
    Mind is like a room. You have to keep only useful things in that room.
    •   AltAdvertisement
  2. #2
    Member level 5
    Points: 1,890, Level: 10
    Achievements:
    7 years registered
    subbuindia's Avatar
    Join Date
    Dec 2011
    Vellalacheruvu(AP), India
    Posts
    86
    Points
    1,890
    Level
    10
    Re: Why is the capacitance between gate and drain is almost zero after pinch off?
    Quote Originally Posted by iVenky View Post
    Thanks in advance.
    Hi friend.........
    I think the current Igs is zero, so there is no capacitance between drain and gate.
    Welcome for the suggestions to improve quality of learning, analysis and research that useful to the globe.
    •   AltAdvertisement
  3. #3
    Advanced Member level 5
    Points: 39,734, Level: 48
    Join Date
    Mar 2008
    USA
    Posts
    6,421
    Points
    39,734
    Level
    48
    The channel is what connects gate plate capacitance to the drain
    (and source). When the channel goes away only the overlap &
    fringing capacitance is "hooked up", the rest is returned to body
    instead of the inversion sheet when not inverted.
