Baube
Hey guys,
I'm quite new here... I might need some help to process and correct the signal I'm getting from my microcontroller.
It's a PWM driven by a Sinking Output (~24V), connected to 2 Serial Resistors (15-15 Ohm) and a LED (3.2V @ 700mA)
At 1kHz the signal looks kinda clean, but as the frequency gets higher, the signal goes from square to kinda sinus.
What you see there is the signal passing throught 1 resistor (15 Ohms).
Any idea what kind of approach I should use ? Filter (LC ? RC ?) ? Comparator with Op-Amp ?
[EDIT] The microcontroller I use has 8 High-Current Sinking or Sourcing Ouputs. Up to 2A each. The source I'm using to power everything is a Weidmuller PowerSupply 120W - 24V [/EDIT]
Thanks,
-Baube.
Thanks,
-Baube.
