ocdongza
Newbie level 2
I am a Newbie of HFSS
I am a Korean, and I am not good at writing English.
I want to know how to setting ports in GSS structure in HFSS
I explain this structure more specifically.
there are three pins like this |||
the first pin is a ground. the others are signal pins.
In simple GS structure, it is easy to set port. because the port take possession of part between Ground and Signal by using the lumped port method in HFSS.
However, in GSS structure in a row, if I use the same method above, the HFSS program says warning that Ports are overlapped.
How can I set ports like this structure?
please answer this problem. thanks
