eltonjohn
simplertj
I've been playing with SimpleRtj https://www.rtjcom.com/home.html
this is kind a nice concept .. The deal is to prelink java applications (classes) then they are downloaded to be executed much faster by the java machine . Has anybody used this concept .. I just did a port of the java machine to a 51 using keil . I'm trying to see how can i use the banking model with several java programs ..! I'm not a Java guru . i'm learning it from its C sources as i go along! (weird hein?)
The philosophy of java is "PORTABILITY" write once run many
it means that a program should be able to run on a PC and on Cellphone
from that respect this is interesting .But to really make it happen a lot needs to be done ..
But MAYBE we can start a JAVA discution group right here!
