kabaza
Junior Member level 3
Hello!
I am trying to get AT89s52 to read 4 bits coming from decoder(HT12D)
the bits are read on the AT89s52 from P3.2-->P3.5
I tested and the bits arrive correctly to the decoder.
ALso, the at89s52 is interfaced with lcd 16x2. I tried reading then masking it with no use. Sometimes I get black box or a random number but by changing numbers so to get different from HEX array!
Thanks!!
Summary: 1)4 bits connected from HT12D to p3.2--->p3.5
2)Then, from P0 to LCD(8bit mode)
3)Tried writing random words on LCD and worked!
4)HT12D gets correct info!
Thanks!!
;8 bit LCD routines with check busy ;flag before sending data, command to ;LCD
LCD DATA P0 ;define LCD data port on port 0
BUSY BIT LCD.7 ;define LCD busy flag
E BIT P2.5 ;define LCD enable pin on port 2.2
RS BIT P2.7 ;define LCD register select pin on port 2.0
RW BIT P2.6 ;define LCD read/write pin on port 2.1
IN DATA P3 ;define input port
VT BIT IN.7 ;Valid transmission
ORG 00H
LCD_INIT:
MOV A,#38H ;2 line 5x7
ACALL COMMAND
MOV A,#0CH ;LCD on cursor on
ACALL COMMAND
MOV A,#01H ;clear LCD
ACALL COMMAND
MOV A,#06H ;shift cursor right
ACALL COMMAND
MOV DPTR,#HEX
wait: JNB VT,WAIT ;No valid transmission yet
mov a,#01h
acall COMMAND
mov a,#87h
acall COMMAND
MOV A,IN ;Copy P3 into reg. A
ANL A,00111100B
RR A
RR A
MOVC A,@A+DPTR
ACALL DATA_DISPLAY
MOV DPTR,#HEX
CLR A
SJMP wait
COMMAND:
ACALL READY ;is LCD ready?
MOV LCD,A ;issue command code
CLR RS ;RS=0 for command
CLR RW ;R/W=0 to write to LCD|
SETB E ;E=1 for H-to-L pulse
CLR E ;E=0 ,latch in
RET
DATA_DISPLAY:
MOV LCD,A ;issue data
SETB RS ;RS=1 for data
RET
READY:
SETB BUSY ;make P0.7 input port
CLR RS ;RS=0 access command reg
SETB RW ;R/W=1 read command reg
;read command reg and check busy flag
BACK:
CLR E ;E=1 for H-to-L pulse
SETB E ;E=0 H-to-l pulse
JB BUSY,BACK ;stay until busy flag=0
RET
delay: mov r0,#200
loop1: mov r1,#200
djnz r1,$
djnz r0,loop1
ret
ORG 200H
HEX: DB '0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'
END
