+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Points: 198, Level: 2
    Join Date
    Jan 2012
    Posts
    7
    Points
    198
    Level
    operation of current bleeding mixer
    hi I have just started using cadence, can anyone guide me how to check whether a mixer is functioning properly, i.e. it is downconverting the frequency?
    Thanks
    •   AltAdvertisment
  2. #2
    Advanced Member level 5
    Points: 33,570, Level: 44
    Join Date
    Oct 2001
    Posts
    4,799
    Points
    33,570
    Level
    44
    Re: operation of current bleeding mixer
    The most important parameters of a mixer that need to be measured are:
    -Conversion Gain or Loss
    -Linearity (Input Intercept Point as IIP3)
    -Spurious products
    -Ports Isolation
    -Noise Figure
    •   AltAdvertisment
  3. #3
    Join Date
    Jan 2012
    Posts
    7
    Points
    198
    Level
    thanks...but how should i know that the mixer is downconverting the frequency, because for any circuit NF and Conversion gain still exists even if doesnot function as a mixer ....
    •   AltAdvertisment
  4. #4
    Points: 14,896, Level: 29
    pancho_hideboo's Avatar
    Join Date
    Oct 2006
    Real Homeless
    Posts
    2,251
    Points
    14,896
    Level
    29
    Quote Originally Posted by Irshad Ahmed View Post
    Use PSS/PXF or PSS/PAC with local signal as only one large signal.
    See the followings.
    https://www.edaboard.com/thread183131.html
    https://www.edaboard.com/thread169169.html
