+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Points: 211, Level: 2
    Join Date
    Dec 2011
    Posts
    Points
    211
    Level
    problem with gain of narrow band LNA design
    i am designing Narrow band Inductive Source Degenerated LNA using NMOS and 90nm mode using adsl. i am getting proper the frequency response at 2.4GHz for s(2,1) plot but the gain is negative. i don't knw what could be casing the gain to negative. i have attached the plot both as .dds and .jpg and also the schematic of the circuit and the model. can anyone please explain to me what causes the gain to be negative? thanks
    •   AltAdvertisement
  2. #2
    Full Member level 2
    Points: 3,049, Level: 12
    Achievements:
    7 years registered
    Join Date
    Aug 2007
    India
    Posts
    131
    Points
    3,049
    Level
    12
    Re: problem with gain of narrow band LNA design
    Quote Originally Posted by Aytan View Post
    Aytan,
    Power gain is negative, it means you need to double check all DC parameters of your design. Check out, Bias current, Operating point, There is some thing seriously wrong in DC points.
    •   AltAdvertisement
  3. #3
    Join Date
    Dec 2011
    Posts
    Points
    211
    Level
    Quote Originally Posted by girih192002 View Post
    Aytan,
    ----------------------------------------------------------------------------------------------------------------------------------------------------thank you for replying.. but how can i adjust the Dc points? in my calculations i set ID=8mA on the simulation i get ID=340mA!!! even though i set the aspect ratios of the nMOSFETS based on the calculation of ID=8mA... what could be causing this... and would you plz tell me how to fix it....
    thank u girih192992
    •   AltAdvertisement
  4. #4
    Join Date
    Dec 2011
    Posts
    Points
    211
    Level
    plz any suggestions would be appreciated... since i reached a dead end ... thanks
  5. #5
    Advanced Member level 5
    Points: 30,417, Level: 42
    BigBoss's Avatar
    Join Date
    Nov 2001
    Turkey
    Posts
    4,458
    Points
    30,417
    Level
    42
    -W/L Ratios of MOSFETs are huge for 90nm technology...Check them out...
    -When you look at Vds(M1) is 350mV<<1.8V Vgs(M1) so MOS transistor is in triode region so gm is very low...Gain is low too...
    -First, define a proper bias voltages and current for MOS transitors and then try to design the LNA...
