Results 1 to 10 of 10
    Advanced Member level 3
    Points: 4,101, Level: 15
    Aug 2011
    726
    4,101
    15
    Blog Entries
    Methods for measuring power consumed by a ciruit
    What are the methods for measuring the current consumed by a circuit and out put in a LCD
    Points: 4,828, Level: 16
    papunblg's Avatar
    Oct 2010
    Kolkata India
    726
    4,828
    16
    Blog Entries
    9
    Re: Methods for measuring power consumed by a ciruit
    What is the current range?
    1. measure the voltage drop across a resistor in series with the load - simple ohms law, a 1 ohm resistor will drop 1V for every amp of current. it's usual to use a smaller resistor and amplify the voltage drop with an opamp - this also allows you to reference the voltage to 0V (by using a differential opamp circuit).
    Use ADC to convert -> microcontroller->output to LCD
    For idea:-
    ---------- Post added at 00:51 ---------- Previous post was at 00:44 ----------
    https://www.edaboard.com/thread168925.html
    Rajsekhar Nag
    Knowledge Grows When Shared
    Aug 2011
    726
    4,101
    15
    Blog Entries
    inside a 10 x 7W LED
    Points: 52,890, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,941
    52,890
    56
    LCD's use tiny amounts of current, compared to LED's.
    See if you can spot any variation in the overall current draw when the display shows all 8's (all segments lit up), as compared to when few segments are lit up. That might give you a way to estimate what's going on in terms of power consumption.
    Advanced Member level 1
    Points: 3,947, Level: 14
    Created Blog entry 7 years registered
    Dec 2009
    INDIA
    452
    3,947
    14
    Blog Entries
    You can always measure the current at source (for total current withdrawn) or consumed at load (total current consumed), Your question is not very clear, do you mean methods to measure the current?
    The road of life twists and turns and no two directions are ever the same. Yet our lessons come from the journey, not the destination. ~ Don Williams, Jr.
    Aug 2011
    726
    4,101
    15
    Blog Entries
    My intention is to measure the current consumed by a series of LEDs ,
    To measure the power by normal mode and that saved by PWM mode by these in series
  7. #7
    Apr 2011
    12,941
    52,890
    56
    I think you'll need to use this method:
    Measure the voltage across your switching device while it's conducting.
    Also measure current through the switching device while it's conducting. This may not be easy. If you have an oscilloscope then put a low-ohm resistor inline and measure voltage across it.
    Multiply V * A.
    This will give you instantaneous watts wasted as heat through the device.
    Multiply by your duty cycle. This will give you average watts wasted as heat.
    Now you will calculate the theoretical waste if you used a linear resistive method to drop voltage.
    You know the average applied voltage on the LED's, and the average current going through them. You also know your supply voltage. From these figures you can calculate what amount of power you would have been wasting.
  8. #8
    Newbie level 6
    Points: 217, Level: 2
    Dec 2011
    11
    217
    Quote Originally Posted by papunblg View Post
    For idea:-
    I agree with your post sir,
    :D
    I want to ask how to make characters at row 2 in LCD sir? how its program?
    visit my site also ELECTRONICS IS FUN
  9. #9
    Aug 2011
    726
    4,101
    15
    Blog Entries
    I dont want accuracy in the values we get, I want to calculate just the rough value in power we saved.
    Btw, any PIC based project available for this ?
  10. #10
    papunblg's Avatar
    Oct 2010
    Kolkata India
    726
    4,828
    16
    Blog Entries
    9
    Pic16F876A(for example) contains inbuilt ADC. So the circuit will be simple as there is no external ADC in this case. Search this forum.
    Rajsekhar Nag
