[SOLVED] Micro controllers programming
prasad70
Member level 3
Can someone please explain which language is more convenient to use for PIC when a complex and large code is needed ?
I am bit confused to which language i should forcuse on .
thk
Definitely C. You can insert asm snippets when you need precise timing or specially compact code.
There are some C compiler. Hi-Tech, CCS, MikroC, from Microchip itself C18 (Microchip compiler starts for PIC18 and above)
-C18; no library (don't know free or pay)
-Hi-Tech; no library, free version also have pay version.
-CCS; have library, need to buy. Free version very limited.
-MikroC; have library, need to buy. Free version also limited.
So far, I just use Hi-Tech compiler. Maybe other share experience other compiler.
No Doubt go for 'C'...use CCS complier...the 'BEST'..
Hope it helps you out :)
Regards,
Santosh kumar
Can someone please hlep me to find a good document/lessons in the net where i can get a basic idea about C
Hello!
MikroElektronika - MicroC
When somebody wants to know how to drive (and does not know anything about the signs
and indications of the road), you give him first a book, not a car.
Same here. Apparently he wants a basic idea about C, so the best way to start is with a book
and a PC.
Dora.
Hello!
and a PC.
Dora.
No! If you whant to drive You need both car and training! You cant be driver only with book, and without car.
Mikroelektronika have good support for MicroC and not so hard how You think. ;-)
Did You try best school on the World : Internet - Google ?
Try this on Mikroelektronika web site:
User Projects - mikroElektronika
PIC Microcontrollers - Programming in C - Free Online Book - mikroElektronika
at this Mikroelektronika address You have free compiler and free eBooks all with free examples:
Downloads Page - Software, Drivers, Schematics, User Manuals - mikroElektronika
Dora You see not so hard to be good driver, first you must whant to be driver! ;-)
Good driver can be only if You whant to. And best is for start to sit in mercedes then in tata nano
Thank you all. I got usful direction and information from you all at the end. :)
