Using a wireless motion sensor to shut off power [HELP!]
mtalia86
Newbie level 2
Hello everyone, i have a little project that requires a rather unusual device
Basically i need to have a wireless motion sensor with a 2 hour time delay to shut off the power to a 240v device.
so if the motion sensor doesn't detect any motion for a period of 2 hours it must wirelessly cut the power to the device, then once it detects motion again it would turn it back on.
Would anyone here know how i would go about doing such a thing?
Thank you in advance
Matthew
Does it have to be wireless as in radio ?
or did you really mean non-contact ? The infrared motion detectors used in the alarm industry along with a timer unit could be adapted for your use :)
Dave
The infrared motion detectors used in the alarm industry along with a timer unit could be adapted for your use.
A standard PIR light switch will be cheaper. An universal time relay configured as retriggerable off-delay should do.
I wanted the sensor to be wirelessly turning off the device, yes as in radio receiver. could you give me a good online store to buy these components?
