[SOLVED] Zigbee: Send an AT Command from a API firmware to a AT Firmware
striker07
Newbie level 2
Hello there!
I'm working on a project that uses ZigBee for communication (Pro S2B). In this project, the coordinator uses the API firmware and the end devices / routers uses the AT firmware (for transparent operation). My doubt is how to send a remote AT request from the coordinator to another device. I've tried to send the '+++' data, using the ZigBee Transmit Request frame type (0x10), but I didn't received only a ZigBee Transmit Status (0x8B) as response. I mapped the serial interface of the end device, and it received the data, but only transfer the '+++' to the serial interface. How I can make the device to recognize this as a command? If I send a ND from the coordinator, it responses successfully.
(sorry for bad English...)
Solved. The command should be inserted in a frame of type 0x17 (Remote AT Request) and it replies in a 0x97 (Remote AT Response) frame.
