Analogstudent
Newbie level 5
Hello all,
Is there anyone out there who has used, the curve fitting optimization in HSpice?
I have designed a circuit that has 6 bias parameters.
The circuit outputs for different input frequencies should fit a given curve by optimizing those 6 parameters. I found something on this webpage which is just similar to HSpice manual:
but I couldn't find any real example for curve fitting optimization.
I would be quite thankful if you can help me with this problem.
Analogstudent
Analogstudent
