how to sim dc PSRR/CMRR
zeldazzz
Junior Member level 3
PSRR and CMRR is worsen by the mismatch of the device. How to simulate it in spectre to get the reasonably close to reality result without using monte carlo. Thank you.
I believe you'll find your DC CMRR and PSRR dominated by Early voltage and
bias deviations, more than Vbe / VT mismatch. The question you have to
ask is whether these aspects are well modeled. This is the only way to get
"reasonably close", and it's not something we can help you with - it's between
you, the foundry and your ability to verify model accuracy where it counts.
If you're convinced that mismatch is the primary issue, then put mismatch
sources all over your circuit and shotgun it with parametric analysis. MOS
is easy, just a series gate vdc. Making the mismatch reasonable per area is
on you.
But I think your effort is better spent elsewhere.
