+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Advanced Member level 3
    Points: 3,812, Level: 14
    Join Date
    Jun 2011
    Posts
    839
    Points
    3,812
    Level
    14
    -20dB slope at crossover frequency in smps?
    why, in smps feedback loop, ....why does the overall closed loop gain have to be going down at -20dB per decade at the crossover frequency?
    I would have thought -40dB would have been ok too?
    Surely, as long as the closed loop gain is <1 for frequencies above the crossover frequency then its fine.........(as long as the phase is always >45 degrees above the crossover frequency too.)
    so why does the slope of the closed loop have to be going down with a gradient of exactly -20dB per decade at the crossover frequency?
    •   AltAdvertisement
  2. #2
    Advanced Member level 5
    Points: 20,736, Level: 34
    Achievements:
    7 years registered
    Join Date
    Jan 2011
    Posts
    3,388
    Points
    20,736
    Level
    34
    Re: -20dB slope at crossover frequency in smps?
    I've never heard anyone say that it has to have a certain slope. In most cases (like with voltage mode converters) it will be going at -40dB or even -60dB at and above the crossover. In general I'd consider a higher slope to be preferable (more filtering of ripple).
    1 members found this post helpful.
    •   AltAdvertisement
  3. #3
    Super Moderator
    Points: 261,156, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    45,615
    Points
    261,156
    Level
    100
    The loop phase is directly linked to magnitude slope by elementary network theory laws, respectively can only get worse by introducing additional delays. For a minimal phase negative feedback system, 20 dB/decade slope refers to 90° phase margin and 40 dB to 0° respectively perfect oscillation condition.
    You should additionally consider, that a switched mode system usually involves a typical delay of 0.5 switching period.
    •   AltAdvertisement
  4. #4
    Newbie level 6
    Points: 243, Level: 2
    Join Date
    Jul 2012
    Posts
    11
    Points
    243
    Level
    Quote Originally Posted by FvM View Post
    I am wondering if phase margin is big enough, do we still need magnitude slope to -20db/dec at at crossover frequency?
