Results 1 to 2 of 2
    Full Member level 6
    Points: 3,600, Level: 14
    cks3976's Avatar
    Aug 2007
    India
    346
    3,600
    14
    Calculating the Output Capacitance of a Device
    I need to calculate the output capacitance of a CPLD. I have seen Input capacitance specs in many data sheets, but not output capacitance. Can someone please explain how can we calculate this parameter ?
    Thanks in Advance,
    Subbu
    Points: 260,190, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,437
    260,190
    100
    Re: Calculating the Output Capacitance of a Device
    Did you realize, that an output can only show a capacitance, if it's tri-stated? I reviewed some CPLD data sheets and found a specification in each case. In so far I wonder, if you have been looking for the right specification?
    The devices I checked had both an input pin and I/O pin capacitance specification. The latter applies to a tri-stated output.
