+ Post New Thread
Results 1 to 14 of 14
  1. #1
    Points: 668, Level: 5
    Join Date
    Jun 2009
    Posts
    Points
    668
    Level
    Test Bench for CIC decimation(5) filter
    Can any one write a test bench to test this CIC filter...
    basically i'm passing 3 sine waves of frequencies 8 MHz , 16MHz and 24 MHz in 3 separate cases with 80 MHz sine wave being the sampling signal.
    I've to take 10 samples , 5 samples and 3.33 samples respectively for each of above cases. below is the excel conversion of a sine wave taking 10 samples at equal duration (i.e 2*pi / 10 = 360 degrees / 10 = 36 degrees duration)... i.e, at 36 degree, 72 degree,108 degree....360 degree.
    test bench shall have a text io directive to read 18 bit data input from a text file and to write output to another text file.
    using text IO is OK, but i just need a test bench , at least with out text IO directives.
    Can any one help ?
    decimation factor is 5.
    36 0.628318531 0.58778525229247300000 77042.1885884790000 010010110011110010
    72 1.256637061 0.95105651629515400000 124656.8797038380000 011110011011110000
    108 1.884955592 0.95105651629515400000 124656.8797038380000 011110011011110000
    144 2.513274123 0.58778525229247300000 77042.1885884791000 010010110011110010
    180 3.141592654 0.00000000000000012251 0.0000000000161 000000000000000000
    216 3.769911184 -0.58778525229247300000 -77042.1885884790000 101101001100001110
    252 4.398229715 -0.95105651629515400000 -124656.8797038380000 100001100100010000
    288 5.026548246 -0.95105651629515400000 -124656.8797038380000 100001100100010000
    324 5.654866776 -0.58778525229247300000 -77042.1885884791000 101101001100001110
    360 6.283185307 -0.00000000000000024503 -0.0000000000321 000000000000000000
    -- Module Name: cic.vhd
    -- Target Devices: XC6VSX315t-1ff1156
    -- Tool versions: ISE 12.2
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    use ieee.std_logic_unsigned.all;
    entity cic is
    generic(CI_SIZE : integer := 18; -- cic input data width
    CO_SIZE : integer := 30; -- cic output data width
    STAGES : integer := 5);
    ce : in std_logic; -- clock enableport (clk : in std_logic; -- system clock (80 Mhz)
    ce_r : in std_logic; -- decimated clock by factor of 5 used in comb section
    rst : in std_logic; -- system reset
    d : in std_logic_vector (CI_SIZE-1 downto 0); --input data
    q : out std_logic_vector (CO_SIZE-1 downto 0)); --output data
    end cic;
    architecture syn of cic is
    -- array definition for integrator and comb section
    type d_array_type is array (STAGES downto 0) of std_logic_vector(CO_SIZE-1 downto 0);
    -- array definition for comb section
    type array_type is array (STAGES downto 1) of std_logic_vector(CO_SIZE-1 downto 0);
    signal d_fs : d_array_type;
    -- used in the integrator section
    signal d_fsr : d_array_type;
    -- used in the differentiator section, at rate r
    signal m1 : array_type;
    signal id : std_logic_vector(CO_SIZE-1 downto 0):= (others =>'0');
    -- to use for sign extended version of the input
    begin
    -- output data
    q <= d_fsr(STAGES);
    -- input data (d input is sign extended to 30 bits)
    id(CO_SIZE-1 downto CI_SIZE) <= (others => d(CI_SIZE-1));
    id(CI_SIZE-1 downto 0) <= d;
    -- integrator section
    process(clk)
    begin
    if(clk'event and clk = '1') then
    if(rst = '1') then
    d_fs(0) <= (others => '0');
    for i in 1 to STAGES loop
    d_fs(i) <= (others => '0');
    end loop;
    elsif(ce = '1') then
    d_fs(0) <= id;
    d_fs(i) <= d_fs(i-1) + d_fs(i);
    end loop;
    end if;
    end if;
    end process;
    -- differentiator (comb) section
    process(clk)
    begin
    if(rst = '1') then
    d_fsr(0) <= (others => '0');
    m1(i) <= (others => '0');
    d_fsr(i) <= (others => '0');
    end loop;
    d_fsr(0) <= d_fs(STAGES);
    if (ce_r = '1') then
    m1(i) <= d_fsr(i-1);
    d_fsr(i) <= d_fsr(i-1) - m1(i);
    end loop;
    else
    m1 <= m1;
    d_fsr(i) <= d_fsr(i);
    end loop;
    end if;
    end if;
    end if;
    end process;
    end syn;
  2. #2
    Advanced Member level 5
    Points: 37,091, Level: 47
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,756
    Points
    37,091
    Level
    47
    Re: Test Bench for CIC decimation(5) filter
    we cant write a testbench for you. - do you have any specific questions?
    •   AltAdvertisment
  3. #3
    Super Moderator
    Points: 251,591, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    43,812
    Points
    251,591
    Level
    100
    Why do you want text_io to read in a sine from a text file? Generating a sine is one line of code in the test bench.
    - generate the reset signal
    - generate clk and ce_r by processes with wait statements
    - generate the input signal using ieee.math_real functions
    1 members found this post helpful.
  4. #4
    Join Date
    Jun 2009
    Posts
    Points
    668
    Level
    I have written following test bench, but getting syntax error while simulating this code...
    can anyone help me in correcting this code.. (functional part mainly)
    LIBRARY ieee;
    USE ieee.std_logic_1164.ALL;
    use ieee.std_logic_arith.all;
    use ieee.std_logic_signed.all;
    use std.textio.all;
    use ieee.std_logic_textio.all;
    -- Uncomment the following library declaration if using
    -- arithmetic functions with Signed or Unsigned values
    --USE ieee.numeric_std.ALL;
    ENTITY CICTEST IS
    END CICTEST;
    ARCHITECTURE behavior OF CICTEST IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT cic
    PORT(
    clk : IN std_logic;
    ce : IN std_logic;
    ce_r : IN std_logic;
    rst : IN std_logic;
    d : IN std_logic_vector(17 downto 0);
    q : OUT std_logic_vector(29 downto 0)
    END COMPONENT;
    --Inputs
    signal clk : std_logic := '0';
    signal ce : std_logic := '0';
    signal ce_r : std_logic := '0';
    signal rst : std_logic := '0';
    signal d : std_logic_vector(17 downto 0) := (others => '0');
    --Outputs
    signal q : std_logic_vector(29 downto 0);
    file in_file:text is in "cic_in.txt";
    variable inline: line;
    -- Clock period definitions
    constant clk_period : time := 50 ns;
    BEGIN
    -- Instantiate the Unit Under Test (UUT)
    uut: cic PORT MAP (
    clk => clk,
    ce => ce,
    ce_r => ce_r,
    rst => rst,
    d => d,
    q => q
    -- Clock process definitions
    clk_process :process
    begin
    clk <= '0';
    wait for clk_period/2;
    clk <= '1';
    end process;
    -- reset process
    reset: process
    begin
    rst <= '1';
    wait for clk_period;
    rst <= '0';
    wait for clk_period*10000000;
    end process;
    -- clk enable process
    cenable: process
    begin
    ce <= '1';
    wait;
    end process;
    -- decimated clk process
    cenable_r: process
    begin
    ce_r <= '0';
    wait for clk_period*5;
    ce_r <= '1';
    end process;
    -- generating i/p file
    ip: process (clk)
    variable in_tmp: std_logic_vector(17 downto 0);
    begin
    if(clk'event and clk='1') then
    if not endfile(in_file)then
    readline(in_file,inline);
    read(inline,in_tmp);
    d <= in_tmp;
    end if;
    end process;
    -- generating o/p file
    op: process (clk)
    file file_out:text is out "cic_out.txt";
    variable line_out : line;
    variable output_tmp : std_logic_vector(29 downto 0);
    begin
    output_tmp := q;
    write(line_out, output_tmp);
    writeline(file_out,line_out);
    end if;
    end process;
  5. #5
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    43,812
    Points
    251,591
    Level
    100
    How about revealing the error messages and marking the error locations?
    There's at least a missíng end if in the input file read process.
    2 members found this post helpful.
    •   AltAdvertisment
  6. #6
    Join Date
    Jun 2009
    Posts
    Points
    668
    Level
    ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic/cic.vhd" Line 12: Syntax error near "ce".
    ERROR:HDLCompiler:854 - "E:/lab_fpga/lab3/cic/cic.vhd" Line 8: Unit <cic> ignored due to previous errors.
    ERROR:HDLCompiler:854 - "E:/lab_fpga/lab3/cic/cic.vhd" Line 20: Unit <syn> ignored due to previous errors.
    ---------- Post added at 22:19 ---------- Previous post was at 22:16 ----------
    these are the error messages....besides these i'm not quite sure if we have to include some directives to open files..
    ---------- Post added at 22:24 ---------- Previous post was at 22:19 ----------
    010010110011110010
    011110011011110000
    011110011011110000
    010010110011110010
    000000000000000000
    101101001100001110
    100001100100010000
    100001100100010000
    101101001100001110
    000000000000000000
    these inputs should be feed to the cic filter..
    •   AltAdvertisment
  7. #7
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    43,812
    Points
    251,591
    Level
    100
    Read the error messages more thoroughly. The syntax error is in the component code, not the test bench.
    entity cic is
    port( -- This line is missing
    end cic;
  8. #8
    Newbie level 2
    Points: 221, Level: 2
    Join Date
    Oct 2011
    Posts
    Points
    221
    Level
    fOLLOWING are the errors i'm getting now...
    now cic.vhd functional code is proper without errors....
    but test bench has some errors..
    can you pls help now ?
    ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 139: Syntax error near "process".
    ERROR:HDLCompiler:837 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 145: Type void does not match with a string literal
    ERROR:HDLCompiler:1728 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 146: Type error near line ; current type line; expected type void
    ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 147: Syntax error near "variable".
    ERROR:HDLCompiler:620 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 147: Near std_logic_vector ; type conversion does not match type void
    ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 148: Syntax error near "begin".
    ERROR:HDLCompiler:62 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 150: output_tmp is not a variable
    ERROR:HDLCompiler:841 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 152: Expecting type text for <file_out>.
    ERROR:HDLCompiler:187 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 152: Actual file_out of formal f must be a file
    ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 145: Syntax error near "file".r "process".
    ERROR:HDLCompiler:806 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 154: Syntax error nea
    -- Company:
    -- Engineer:
    -- Create Date: 19:32:29 09/26/2011
    -- Design Name:
    -- Module Name: Z:/lab3/CICTEST.vhd
    -- Project Name: lab3
    -- Target Device:
    -- Tool versions:
    -- Description:
    -- VHDL Test Bench Created by ISE for module: cic
    -- Dependencies:
    -- Revision:
    -- Revision 0.01 - File Created
    -- Additional Comments:
    -- Notes:
    -- This testbench has been automatically generated using types std_logic and
    -- std_logic_vector for the ports of the unit under test. Xilinx recommends
    -- that these types always be used for the top-level I/O of a design in order
    -- to guarantee that the testbench will bind correctly to the post-implementation
    -- simulation model.
    LIBRARY ieee;
    use std.textio.all;
    ENTITY CICTEST IS
    END CICTEST;
    COMPONENT cic
    PORT(
    clk : IN std_logic;
    ce : IN std_logic;
    rst : IN std_logic;
    END COMPONENT;
    --Inputs
    --Outputs
    constant clk_period : time := 12.5 ns;
    BEGIN
    uut: cic PORT MAP (
    clk => clk,
    ce => ce,
    ce_r => ce_r,
    rst => rst,
    d => d,
    q => q
    begin
    clk <= '0';
    clk <= '1';
    end process;
    -- reset process
    reset: process
    begin
    rst <= '1';
    rst <= '0';
    end process;
    cenable: process
    begin
    ce <= '1';
    wait;
    end process;
    cenable_r: process
    begin
    ce_r <= '0';
    ce_r <= '1';
    end process;
    ip: process (clk)
    begin
    d <= in_tmp;
    end if;
    end process;
    op: process (clk)
    begin
    output_tmp := q;
    end if;
    end process;
    END;
    FUNCTIONAL CODE.............................................. ...................
    library ieee;
    entity cic is
    end cic;
    begin
    -- output data
    q <= d_fsr(STAGES);
    process(clk)
    begin
    if(rst = '1') then
    end loop;
    d_fs(0) <= id;
    end loop;
    end if;
    end if;
    end process;
    process(clk)
    begin
    if(rst = '1') then
    end loop;
    end loop;
    else
    m1 <= m1;
    end loop;
    end if;
    end if;
    end if;
    end process;
    end syn;
    ---------- Post added at 16:51 ---------- Previous post was at 16:48 ----------
    This is what i have to do....
    Generate the free running clock, reset for one cycle and ce_r (decimated clock that generates
    one clock pulse for every 5 clock cycles). Clock enable (ce) can be tied to logic 1 so the filter
    is always enabled).
    3. Testing at 8 MHz passband: In this region, the filter is supposed to pass the sine wave with
    some change on magnitude. Apply an 8 MHz sine wave sampled by 80 MHz. This means
    you need 10 samples, each one applied at a 80 MHz clock and it is repeating. Read the input
    data samples from a file using TEXT IO and apply the input to the design. Read the output
    values from the waveform and draw both of the waveforms on the same graph.
    ---------- Post added at 16:56 ---------- Previous post was at 16:51 ----------
    below are the 10 samples of 8 MHz wave taken at equal sine angles of 36 degrees and normalised...i.e, multiplied by 2^17 (input data width 0:17) and then converted to signed binary number..
    010010110011110010
    011110011011110000
    011110011011110000
    010010110011110010
    000000000000000000
    101101001100001110
    100001100100010000
    100001100100010000
    101101001100001110
    000000000000000000
  9. #9
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,756
    Points
    37,091
    Level
    47
    Right:
    at line 139, you're missing an end if.
    and for the rest - you are using '87 file usage. I wouldnt recommended. I would use this format which is '93 format:
    file in_file : text open read_mode is "cic_in.txt";
    and the same for all the other files.
    Another thing - please please please use code tags in your posts.
  10. #10
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    43,812
    Points
    251,591
    Level
    100
    Each error message comes with a line number. Locating the respective line is the first step to identify the error cause.
    I'm under the impression, that you didn't yet take the effort. Why should we?
  11. #11
    Newbie level 2
    Join Date
    Oct 2011
    Posts
    Points
    221
    Level
    I somehow managed to clear most errors.. except one at line 8 of this code in test bench...( i.e, at line readline(in_file,temp); ) and the error message isERROR:HDLCompiler:1728 - "E:/lab_fpga/lab3/cic_work/tb_cic.vhd" Line 140: Type error near in_file ; current type line_file; expected type text
    I'm just started learning VHDL for my FPGA lab.. this is my first lab...so, not that acquainted with syntax of VHDL and using its functions...
    can any1 help me in figuring out what needs to e corrected ?
    read_input: process(clk)
    type line_file is file of std_logic_vector;
    file in_file: line_file;
    variable temp: std_logic_vector (17 downto 0 );
    begin
    file_open(in_file, "cic_in.txt", READ_MODE);
    while not endfile(in_file) loop
    readline(in_file, temp);
    d <=temp;
    end loop;
    file_close(in_file);
    end process;
  12. #12
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,756
    Points
    37,091
    Level
    47
    the problem is you defined your own file type. if you define your own file type, you will have to define your own read functions.
    If you stick with the text file type (from textio) then all the read functions are defined for you.
    And you still havent found the code tags? use code and /code inside square brackets [ ]
    •   AltAdvertisment
  13. #13
    Junior Member level 2
    Points: 724, Level: 5
    Join Date
    Apr 2010
    India
    Posts
    20
    Points
    724
    Level
    Hi TrickyDicky,
    Can you please explain in detail. I dint get your point of defining "own file type". I am also new to VHDL. So need help.
    Regards
    Vinod A H
  14. #14
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,756
    Points
    37,091
    Level
    47
    with this line you have declared a file of std_logic_vector.
    because it is not a standard file type (because you created it) there are no readline functions for it - you have to write your own. you can however use read(file, slv) to read directly to a std_logic_vector (because read is implicitly declared for all file types). But the bahaviour is not garanteed (plus it becomes a data file, not a text file)
    the only "standard" way to read files is to use the "text" file type, that is declared in the textio library. and there are loads of read functions written for that.
