TenmaNeko
Newbie level 6
Hello, I'm using a Cyclone III LS on a board. It's programmed using the JTAG connector and a Serial Device. I need to reprogram the FPGA, but apparently the LS series has a security feature which prevents reprogramming unless a "FACTORY" command is sent via JTAG. I'm using the Altera USB Blaster to connect to the board.
Is it possible to do this using the Quartus II software? If not, are there tools out there that will work with this cable and allow me to send JTAG commands?
Thanks in advance.
Thanks in advance.
