[SOLVED] Writing To EEPROM AT24c512 using AT89s52
muyalrabbit
Newbie level 5
Hi Fallowing Is My Code To Write Value 2 At Address 0x08 Of
EEProm AT24C512 Using AT89s52.
The Code Executes And No Value Is Written On ROM
Help Me Debug This.
;CODE FOR AT89S52
;EEPROM AT24C512
;WRITING VALUE 2 AT EEPROMS 0X08
ORG 0H
VRBLS: ;VARIABLES
SCL EQU P2.0 ;I2C CLOCK
SDA EQU P2.1 ;I2C DATA
I2CDAT EQU 28H ;I2C DATA VARIABLE
SJMP START ;GOTO START
;I2C MODULE START
I2CSTART: ;I2C START
SETB SDA
SETB SCL
NOP
NOP
CLR SDA
NOP
NOP
CLR SCL
RET
I2CSTOP: ;I2C STOP
CLR SDA
SETB SCL
NOP
NOP
SETB SDA
NOP
NOP
RET
I2CWRBT: ;I2C WRITE A BYTE
CLR SCL ;I2C CLOCK LOW
MOV SDA,47H ;SENDING MSB OF I2CDATA
ACALL I2CCLK ;I2C CLOCK
MOV SDA,46H ;SENDING NEXT BIT OF I2CDATA
ACALL I2CCLK
MOV SDA,45H
ACALL I2CCLK
MOV SDA,44H
ACALL I2CCLK
MOV SDA,43H
ACALL I2CCLK
MOV SDA,42H
ACALL I2CCLK
MOV SDA,41H
ACALL I2CCLK
MOV SDA,40H ;SENDING LSB OF I2CDATA
ACALL I2CCLK ;12C CLOCK
RET
I2CCLK: ;I2C CLOCK
SETB SCL
NOP
NOP
CLR SCL
NOP
NOP
RET
I2CACK: ;I2C ACKNOWLEDGE
CLR SCL
SETB SCL
NOP
JNB SDA,I2CAKD
CLR SCL
RET
I2CAKD:
CLR SCL
RET
;I2C MODULE END
;EEPROM MODULE START
EEWRADD: ;EEPROM ADDRESS WITH WRITE ENABLE
MOV I2CDAT,#0A6H ;SEND DEVICE ADDRESS + ENABLE WRITE
ACALL I2CWRBT
ACALL I2CACK
RET
EERDADD: ;EEPROM ADDRESS WITH READ ENABLE
MOV I2CDAT,#0A7H ;SEND DEVICE ADDRESS + ENABLE WRITE
ACALL I2CWRBT
ACALL I2CACK
RET
;EEPROM MODULE END
START:
ACALL I2CSTART ;I2C START
ACALL EEWRADD ;I2C WRITE DEVICE ADDRESS WITH WRITE OPTION
MOV I2CDAT,#0H ;I2C EEPROM ADDRESS LOCATION (1ST BYTE)
ACALL I2CWRBT ;I2C WRITE
ACALL I2CACK ;I2C ACKNOWLEDGE
MOV I2CDAT,#08H ;12C EEPROM ADDRESS LOCATION (2nd BYTE)
MOV I2CDAT,#02H ;WRITE VALUE 2 TO EEPROM
ACALL I2CACK ;I2C ACKNOWLEGE
ACALL I2CSTOP ;I2C STOP
HERE: SJMP HERE ;STAY HERE
END
Code File Is Attached In Text Format For Readability
  • I2C.txt
You are checking on hardware or in simulation?
I am poor at assembly language.
Are you using pullup resistors for the SCL & SDA lines? Increase the delay just two nop instructions will not work.
@Kirangowle
Iam using Proteus 7 Simulator
---------- Post added at 15:09 ---------- Previous post was at 14:59 ----------
@Amol_Shah
Iam Using Port2 (Pins 2.0 & 2.1). They Do Have Inbuild Pullup resistors are they not enough ?
Advice Me.
I am using Proteus 7 and viewing I2c memory module window in debug mode.
Memory Location Is Not Updated (I2C Rom Memory Location 0008 Value = FF instead of 02)
I don't understand what you're doing here. What's send to SDA (P2.1)?
   ACALL I2CCLK
   MOV SDA,45H
   ACALL I2CCLK
   MOV SDA,44H
   ACALL I2CCLK
   MOV SDA,43H
   ACALL I2CCLK
   MOV SDA,42H
   ACALL I2CCLK
   MOV SDA,41H
   ACALL I2CCLK
   RET
Internal pull ups are not sufficient for high speed communication. Increase the delay and use pullups of 2.2k.
MOV SDA,41H?? If i am not wrong you cannot move bit data from one bit location to another directly.
do this:
MOV C,47H
MOV SDA,C
@FVM
47h = MSB bit Address of 28h. We store the value in 28h and MOV to SDA bit by bit
---------- Post added at 16:01 ---------- Previous post was at 15:54 ----------
@Amol_Shah
I Guess Bit Mov Works
Any How Now I Asaigned Those Locations as B0-B7.
And Changed The Code as MOV SDA,B0
Assembler Failed To Assemble So I Change The Code As u Advised
Now Code Is Like Below
MOV C,B0
MOV SDA,C
Thank You
do this:
MOV C,47H
MOV SDA,C
Yes, I'm not aware of a bit to bit MOV instruction of 8051. The original instruction is misunderstood as a MOV direct, direct byte move.
RLC A would be more economic method to output the bits.
Proteus File And Code Attached
  • EEProm.zip
  • I2C.txt
  • I2C.txt
