shaikss
Full Member level 4
Attached is the schematic and different plots.
The schematic is the antenna coil of the RFID reader and tag. The left part of the schematic (Parallel RLC) is the reader and right is tag.
My Question is: Why is a dip found in the parallel resonant circuit (L1) (Plot of 20dB(L1) Vs frequency?
Why the same dip is not reciprocated into another parallel resonant circuit (L0)after coupling ?
Can you please explain the reason for this behaviour?
By changing the coupling factor, again the dip is varying. How they are dependent?
WHat changes do I need to do in order to see smooth curves?
Thanks,
Thanks,
