- Place pads using the Place » Pad command or the Place Pad toolbar button
- Pads are mainly used as part of components but can be used as individual objects, such as testpoints or mounting holes.
- Pad properties are set in the Pad dialog that is displayed by pressing the TAB key while placing the pad or double-clicking on a placed pad.
- If a pad is to have different sizes on the mid layers or bottom layer, check Top-Middle-Bottom in the Size and Shape section. Click on Full Stack and then Edit Full Pad Layer Definition to edit more complicated stack ups.
- Assign a net to the pad, define the pad’s electrical type (i.e. load, terminator or source) and set whether or not the pad’s hole is plated. The NC drilling software selects separate drill tools for plated and non-plated holes.
- Pads can be assigned as Top and/or Bottom Layer Testpoints on both Fabrication and/or Assembly.
- Pads can be set to Slotted or Square holes
- Pads holes can be set as offset from center
- A preview is created at the top of the dialog that changes in realtime.
- Paste and Solder Mask expansion can be set at the pad level bypassing what ever is set in the design rules.
