This error occurs when the clearance value exceeds then the value which is set in rules, to avoid this error
open your pcb Go to
tools > reset errors then Go to
design > rules ( a pop up menu will appear on the left hand side in the menu you will come across the word clearance double click it and decrease the clearance )> apply > ok
then again check DRC..
your error will be removed...
