raksha singh
Member level 4
hello
when diode ' s both side have same voltage 12v.
e.g. 12 v 1amp adapter in one side ,then its positive leg with 1n4007 diode(forward direction ) connecting to 12 v 7 ah lead acid smf battery 's positive terminal and negative terminal of both are common .
adapter will charge battery till battery get its full 12 v then after getting full charge diode's both side have same voltage 12 v
then in that condition does adapter will give current to battey always or will stop current to charge battey ?
